I'm starting down the road of significant changes with my HA install and would like to solicit some discussion & opinions.
I’m currently running HS2 on a Dell PowerEdge 1800 server and have installed an Ocelot and SECU modules for I/O. MainLobby provides the main UI running on a 10†Airpanel. I’m not using MusicLobby at this time because I want to retain VR control of music which is possible with HS & Media Player plug-in. I also prefer my custom Music page in MainLobby that retains the same look and feel as all my other MainLobby Scenes.
Whole-house audio is home grown using a bunch of different equipment and security is handled by wired PIRs & contacts back to the SECU’s as well as a W800 with a few hawkeyes & DS10a’s and HomeSeer scripting.
Over that last few months I’ve purchase an Elk M1 with Ethernet and an extra serial expander for lighting. I’m evaluating both Insteon & UPB for lighting but have only gotten as far as testing UPB with the M1 (Insteon stuff in running on HS right now). I’ve had the M1 and a Russound CAV6.6 on the bench for a number of weeks “getting to know themâ€.
Below are a few of my goals:
1. Install a full featured alarm/security system. I’m off to a good start with the M1 and will use this as the basis for security (and automation).
2. Move all my lighting control, motion & door sensors, door locks, temperature sensors, and VR mic gate status to the M1. I’ll also be adding CO2 & smoke/heat sensors.
3. Better integrate my thermostat (need to choose a model supported by the M1)
4. Roll out new lighting control to the entire house using either UPB, Insteon, or a combination of both.
5. Pull out my existing very complex whole-house audio setup and replace it with the Russound CAV6.6.
6. Dumb down my HS configuration so I can make it reliable again.
I need to keep HS in the mix because I like the product and right now it’s the only way to interface the iAutomated RFID gear. I’ll also use it for VR, TTS and the other advanced functions that the M1 can’t reproduce. I’ll keep MainLobby too because I’m pleased with the way it works and looks. What I’m really trying to understand is how to best make this all work together?
HomeSeer has an M1 plug-in & Mainlobby plug-in and Mainlobby has a M1 plug-in. I’d like to keep everything as simple as possible and most importantly as reliable as possible. In the end, I expect that I’ll get the Elk M1 installed and connected to all the stuff it will control and monitor. With this done, I’ll dig further into ElkRP and use it to automate as much as possible internally in the M1 for reliability.
Once this is complete, I’ll create a new HomeSeer configuration by starting from scratch to compliment the M1 installation and then integrate MainLobby. Can anyone provide some pros & cons about which plug-ins to use to tie these three together?
The CAV6.6 install should be easy (I may tackle this starting tomorrow?), but I’m still working out how I want to integrate it with automation. TTS from HomeSeer through the paging input is a no-brainer and is working well. I’ll also want to be able to turn the backlight off on some of the keypads when we go to bed and maybe select some sources through scripts (these things should be easy to do with HS scripting and the RS232 connection). I’d like to be able to get artist & track title info to the keypads when playing MP3’s from HomeSeer’s Media Player plug-in and not sure how to do this yet. I know that Cinemar has a great CAV6.6 plug-in which I’m sure I’ll check out, but the integration is with MusicLobby which I’m not currently using. I know there are some changes on the horizon at Cinemar, so may consider MusicLobby in the near future. This would solve the Russound integration issues, but I’ll loose the VR control of my music which I use frequently?
I am actively researching a number of other hardware and software solutions, but would like to keep this discussion focused around the products mentioned above. My time right now is very limited so I need to proceed using the stuff I already own and know… there will be lots of time later to try out and evaluate different products.
Very interested to hear from other M1/HomeSeer/Mainlobby users to see how you are “tying it all togetherâ€.
Paul
Paul
