acheslow
So after moving into my new house recently I took the first step in moving up from X10. After a lot of deliberation I decided that I was willing to pay higher prices for UPB devices since the consensus seemed to be that they work more reliably than anything else. I even decided I could live with the delay if it meant higher reliability in the end. So, I ordered the KPE-06 starter kit from Martin and was very excited to finally have near-100% reliability.
I installed the universal dimmer switch in the kitchen to control 3 halogen pendant lights (not low voltage -- there is no transformer) and installed the lamp module in the living room. At first I had a lot of problems with the lamp and realized that it had a CFL bulb in it, so I replaced that with an incandescent and it worked much better after that.
The pendants, however, seem to be causing some problems. It seems like I often have to repeat button presses in order for them to turn off or execute links -- and I'm sure I'm not confusing this behavior with the Super Toggle feature. When running a communications test from UPStart, the test will fail when the lights are on but the dimmer tests fine when the lights are off.
I thought UPB was supposed to work fine with halogen lights? Is there something I can try to get around what seems to be excessive noise from the halogen lights? If I can't get the reliability I was expecting I may as well just switch over to Insteon or Zwave...
Thanks!
Thanks!
