kurtmccaslin
I am building a new home, and have gone 100% LED. I have a variety of different fixtures and bulbs from different vendors. The Simply Automated 11-40 has worked well on all of them except for one type of fixture. It is the Phillips CorePro LED mini cylinder. This fixture will not start up with anything less than 80% brightness. After it is started, it will dim down to a pretty low level. However, I would like to tap a wall switch and directly deliver 40% brightness.
The specs on this fixture say it will dim with "trailing edge (ELV) dimming" If I change out the wall switch to a PCS WS1E, do you think it will work? This switch is rated for ELV transformers, but it is fairly expensive, and I was hoping to hear from someone with experience before I buy one.
Second question: Is there a way to trick the SA 11-40 to brighten to 100% and then dim down, as opposed to dimming up from zero?
