123
I'm done banging my head on this one so hopefully the UPB experts can chime in and tell me the silly newbie mistake I've made!
For example, here's a screenshot of the Transmit Components. It seems to indicate Hold will Fade Up but that's not what happens when I press and hold the top rocker. ???????
Here's a link to the other screenshots (Advanced, Options, Rocker Switch): http://imgur.com/a/NSd4t
FWIW, these are two US1-40 Dimmers that are part of a Starter Kit. The kit also includes a US2-40 Dimmer that works properly when operated manually.
ADDENDUM
It probably doesn't matter but I'll throw it in anyway, the back of the device clearly says US1-40 and that's what UpStart reports as well. The included instruction sheet indicates US11-40 which I believe simply means it's a combination of a US1-40 body with a ZS11 rocker switch.
- I have two Simply Automated US1-40 Single Rocker Dimming Switches, Firmware V2.18.
- I used UpStart V8.0 Build 38 to program them. It reports the two devices have been successfully programmed.
- I can use UpStart to turn on the switches and set their dim level. They also respond to scenes that set their dim level.
- What I can't do is manually set the dim level at the switch itself! Holding the top/bottom of the rocker fails to brighten/dim the load (incandescent bulbs). All the rocker accomplishes is to turn the load on/off.
ADDENDUM
