I wanted to put some sort of surge protection on the serial cable between the PIM and panel. I had looked at RJ45 surge protectors but the clamping voltage is 7.5V. RS232 specifies a +/- 12V. It looks like I need to purchase a DB9 surge protector, which has a clamping voltage of 18V, and make two RJ45 to DB9 adapters.
The Tripp Lite DB9 surge protector without a grounding cable. It looks like it grounds the surge through the metal connector. With the RJ45 to DB9 adapters there wouldn't be any connection to ground.
http://www.tripplite.com/en/products/model.cfm?txtModelID=157
Black Box has a DB9 with ground connector, but it is four times the price.
ttp://www.blackbox.com/Store/Detail.aspx/RS-232-Surge-Protector-DB9/SP361A%C4%82R2
I'm curious to see what others have done to protect the panel serial port.
