UPB PIM pinout info needed
electron
Administrator
Staff member
I am trying to build a custom cable for my serial UPB interface (for use with the Elk M1), but the standard 3 pins don't seem to do the trick. Whenever I use that setup, I can hear the UPB PIM buzz 3 times for each command, and also see the light blink 3 times. This does not happen with the regular serial cable, so I assume I must be missing some pins. Has anyone tried building a custom cable yet?
howardbuck
This is the pinout I use for my HAI UPB PIM. I think they should all use the same configuration.
PIM RJ-25 DB-9 (connected as DTE)
1 DTR 4 DTR
2 TX 2 RX
3 RX 3 TX
5 GND 5 GND
Howard
electron
Administrator
Staff member
I found the docs on the PCS site which shows the following config:
2->2 (RD)
3->3 (TD)
4->4 (DTR)
5->5 (ground)
Seems to work so far.
