upstatemike
Been reading up on UPB a little bit but a few things are not clear to me from the literature (that I have read so far).
1- I need to understand scenes better. Am I correct that a regular switch can trigger any of the 250 scenes when it is turned ON (thus enabling virtual 3-way arrangements as well as dimming scenes)? Can the same switch trigger a different scene from a double tap and a third scene from when OFF is pressed?
2- If UPB keypads trigger scenes then I assume they do not have status LEDs (since there is nothing to sync an LED to)?
3- I understand that the LEDs on UPB devices are dual color and they can be programmed for different behaviors. Is there a good reference detailing the options available? Would that be in the Upstart doc? Is there a comparison chart someplace that lists the LED color combinations by brand? Does anybody do a Blue/White or Blue/Yellow combo?
