I think it's about time for an update on this Audio PC I'm struggling to get going.
Some of you probably know that I originally bought 4 of the same type soundcards. Problem #1, to be sure. First off I couldn't get the 4th card to list in Girder or Winamp. Despite multiple formats, driver versions, and install/re-install of hardware, it wasn't happening.
So I took out one soundcard and tried using the onboard audio as the 4th. YaY! It works...kinda. Now the 3rd soundcard only has it's input volume control listed in Girder even though it was selectable as an output in Winamp. Hrm...ok. Using the onboard audio worked, so let's try another soundcard with a different chipset. 4 days later and a little bit poorer I now have a Chaintech 7.1 soundcard.
So we've got 2 AOpen AW850s, a Chaintech 7.1 and onboard audio. Fresh install, and hey! Everything works! Woohoo! ...oh wait, one of the Winamp outputs isn't set to use the 2nd Aopen card. Gotta fix that you know. Well crud, now the comp freezes when trying to use the 2 AOpen cards. Hrm... Couple of formats later, yup it ain't happenin'.
I know, let's go get another soundcard! Couple days later, trip to Best Buy pay they're insane markup on computer hardware. Alrighty, now we're cookin' with gas. We've got 1 AOpen AW850, 1 SB Audigy LS, 1 Chaintech 7.1, and onboard audio.
Everything's different, we can't possibly have any problems now. WRONG!
Fresh install of Windows and Winamp, we've got a new problem, only it's software this time. Despite having copied multiple instances of Winamp and being able to run each independatly and at the same time something strange has occured. All the different copies are using the same plugin file. Change the output in one changes the output in them all. Well that's not right, let's try a fresh install of everything again. We'll get this sorted out.
Windows is installing...do do do...huh, my CPU fan doesn't seem to be moving much air. Let's check it out while it's still spinning. Nope, not much air at all. Well Windows is still installing and there's not much for me to do, so let's take it off. Grab my trusty Leatherman, get out my philips blade.... do do do.
***SCREEEEEECH***FAP FAP FAP***
hrm, my screwdriver seems to have slipped and broken off a bunch of the blades. Good thing there's another fan under that one. Oh, no wait. The blades that broke off have gotten themselves lodged under the other fan and broken some of it's blades. Well there's still some flow, it should be all right.
WRONG!
Now my APC is stuck somewhere between format and fresh install and overheats within 20 seconds of bootup.
New Zalman cooler on the way!
If it were easy, I'd be able to do it.
Oh, but I have found the speakers and receiver I'm going to buy if I can get the computer part running. Heck, maybe even if I can't get it running!
Sony STR-DE185
AudioSource IC8S Round Ceiling Speakers
WRONG!
Sony STR-DE185
