Rupp, When I was Beta testing HS 2.0, I eventually tried loading it with no external or 3rd party plugins, just running it with X-10 and a CM11A, and my test box ran perfect for the entire 30 trial period without a crash or single error. The biggest problem is with HST trying to support so many different HA options and devices, there are thousands upon thousands of configurations their customers may try to setup in their home. Not to mention the fact that not everyone is running the exact same PC hardware or MS software and revision level. The fact that MS software itself is different across their platforms really makes it hard on software developers to develop software that is supported across different MS platforms. Want proof... Try installing AOL 9.0 to a MS W2K3 Server.Rupp said:I upgraded and have been running without problems. Of course I run a minimalist plugin count.
I totally agree "Pod". This is what users need to keep in mind. The more plugins you load the more likely it is that something will fail. This is probably why I've had so few problems. I simply do not need but a few plugins. I've witnessed user after user load plugin after plugin and then complain that their system is unstable. I just do not do this.The Pod said:Rupp, When I was Beta testing HS 2.0, I eventually tried loading it with no external or 3rd party plugins, just running it with X-10 and a CM11A, and my test box ran perfect for the entire 30 trial period without a crash or single error. The biggest problem is with HST trying to support so many different HA options and devices, there are thousands upon thousands of configurations their customers may try to setup in their home. Not to mention the fact that not everyone is running the exact same PC hardware or MS software and revision level. The fact that MS software itself is different across their platforms really makes it hard on software developers to develop software that is supported across different MS platforms. Want proof... Try installing AOL 9.0 to a MS W2K3 Server.Rupp said:I upgraded and have been running without problems. Of course I run a minimalist plugin count.
The Pod
