nadeau2000
How do you hook up an Uplink 1500 to a M1-EZ8 with the speaker that it comes with.
The Uplink has to be hooked up to output 2 and
the global setting must be set to 12 volts.
If you hook up two speakers and the Uplink to output 2 neither
will function properly.
Is there a way to hook up the speaker(s) to output 3 and have both a fire
alarm and a burglary alarm? ( i.e. the different sounds)
I do have a elk-100 can this be used in some way?
:unsure: :unsure: :unsure: :unsure: :unsure: :unsure:
