using "extra pair" in cat-5 for speaker
raymondh
Will there be any problems connecting the ELK-SP15 to 2 unused pairs from a cat-5 run to a keypad on an M1?
I have it hooked up and it seems to be working but I want to make sure this isn't a problem. One thing that I have noticed is the speaker makes a clicking type noise every couple of seconds but I think that is the watchdog on output 2.
Sorry for all the questions...
Spanky
Raymond,
The M1 should not be watchdoging in normal operation. If it is watchdogging you could hear a click when the M1 power back up.
raymondh
Raymond,
Every 1-3 seconds I hear a click (or thump) from the speaker connected to output 2.
I'm thinking about removing the siren from that output and connecting a bunch of the small ELK speakers around the house. How man in series can I connect on output 2 along with the ELK speaker that came with the kit?
123
Depending on the number of speakers, you'll probably have to connect them in a combination of parallel and serial configurations. The final impedance should not be below 4 ohms.
Here's a simple online calculator for parallel reistance: http://www.sengpielaudio.com/calculator-paralresist.htm
So one 8 ohm Echo speaker and three 32 ohm SP-12s, all in parallel, will result in 4.57 ohms. That's what I have in my house and I plan to add a fourth speaker (another Echo). However, I won't be able to place it in parallel because that will reduce the total below 4 ohms. I'll probably put the two 8 ohm Echos in series and then in parallel with the three SP-12s.
raymondh
So one 8 ohm Echo speaker and three 32 ohm SP-15, all in parallel, will result in 4.57 ohms.
That's perfect since I want to add 3 SP12 speakers.
123
whoops, I meant the SP-12s ... they're 32 ohms! I modified my original post so that I don't lead anyone astray.
