Using XTB-II to Phase Couple Insteon
upstatemike
I was wondering if the frequency window on the upcoming XTB-II will be wide enough to phase couple Insteon signals as well as X-10. I know that is not its purpose but Insteon will cross over on UPB couplers so I was wondering if the same would be true for the XTB-II?
JeffVolp
Interesting thought. Yes, that probably will work. The two series-tuned LC networks would be in series across both phases. And there is a 120KHz tank network in the middle. That is not a high-Q circuit, so it should still work fine at 135KHz.
DeLicious
why would you need to phase couple Insteon like this? Isn't that the point of the (only) existing RF devices is that it phase-couples over RF?
upstatemike
Yes but if I have a hard wired coupler in place for something else and it handles Insteon as well then I don't need to set up the RFLincs. I wasn't suggesting using an XTB-II to couple Insteon exclusively.
