jrfuda
Guys, I came home today to find my Viewpad had performed a memory dump.
A reboot later, everything seemed fine, but about an hour later it happened again, accompanied by lots of unpleasant clicking.
The HDD's failing, I can get it to boot to windows if I'm lucky, but usually nothing.
I removed the HDD and it appears that I can boot from the network. Does anyone know how to pull this off? I have an XPPro disk that I can install on this machine (either from the CD, or I can install it to one of my network HDDs and install t from there.
The HDD that was installed in the Viewpad was a Fujitsu MHR2020AT, 20GB, 4200RPM HDD. The cheapest identical replacement I've found is $71. Do you think it would be worthwhile to go for a 5400 or 7200RPM HDD instead,or do you think I'll have some heat/power issues (The viewpad runs hot as it is!).
So here are the options I have after I get a replacement drive:
- 1. Reinstall Windows over the network
2. Buy a docking station for $100+ and reinstall from CD
3. Restore an image (backup) of the old system using the network or CD as above. (If I can find an old image)
4. Install the old and new HDDs on one of my desktops and attempt to copy the image of the old to the new
