You've been granted Beta access to this site, allowing you to explore some of the new features while they're still under construction. More information can be found in the Beta forum.
I'm using so many downloaded, customized links that I can't get anything to work anymore. I want to put the HS Web pages links back to the original condition. But I'm not sure how to do that. Help?
I believe there is a file named links.html or .html or something like that, if you remove it (just rename it to something totally different), it should use the default template.
That was it. Thanks electron. I still have a bunch of wayward links attached. I want to clear out everything and get it all set up correctly. I have a long night ahead of me.
