Since I started this, I guess I'll comment.
I already have a CF01. It wasn't really doing much which is why I though that I might be able to put it into service in my van as part of a carPC. I tried it as a full PC but it is way underpowered and limited in the # of serial ports to connect things to. But, I now know that the screen will wash out in regular sunlight when mounted anywhere near the dash since I tried it on Friday. So I figure the CF01 is out of the final design but it is still useful to test things. It looks like I will need an LCD monitor with enough brightness to be readable in the front seats and high enough resolution to be read clearly/quickly (I'l be driving).
Now, since I am working with a conversion van, space is not a problem. I can mount the CPU, a full size one anywhere - although on the floor between the front seats would allow easy access to the CD/DVD drive. (Possible a home made cabinet for the CPU, with cup holders, map pocket, CD holder, and other stuff could be built.) As long as it matches the wood trim already in the vehicle.
There are pplenty of connection points for the AV stuff - I already have two radio's in the van. One dash mount for all occupants and one in the rear that uses headphones, along with a DVD /TV that came installed. I already put a small 5.6" video screen in the front passenger seat to view the DVD's that are playing for the back seat passengers. I also hard wired my Garmin Streetpilot and mounted it on the dash.
I have all the miscellaneous parts other than the screen. I will most likely have to bite the bullet and get a 7" Lilliput or Xanac(?) screen.
