Originally posted on AVSforum.com
WaterCooling a media rack
I have been tempted to water cool a couple of Tivos, an HTPC and a PC home automation server that is all in my media equipment rack / closet. I was thinking of plumbing some type of distribution hub for the supply side with regulation on each tube for each device to balance the system. The individual hot water lines would drop into a water tank which would have the pump which would then pump to a radiator in a different room to keep the media closet cool. The output of the radiator would go back to the distribution hub.
Of course, with all this expensive hardware on a common cool system, I would need to regulate the temps which I can easily do with the home automation server (running Homeseer) and 1-wire sensors. I can also monitor the motherboard temps with Homeseer HA software (MSCTemp Homeseer script) as well using SpeedFan software. I don't think I can monitor the board temp of the tivos (TivoWeb?), but a 1-wire temp sensor should be OK for that purpose. I will monitor the current temps with normal fan cooling to get a baseline of what temps are normal. The Homeseer automation server can provide alerts if temps rise above normal on any of the devices. Homeseer could also shutdown the offending unit (via LAN messenging, serial or IR commands) or all devices if indicative of a coolant failure before shutting itself down and sending email / vmail / page / alarm system alerts.
Here are some thoughts on equipment for the above:
PVC piping running up the side of the equipment rack for the distribution hub. Off of each T on the pressure side, would be a simple rotary valve to tweek water volume to the device. I have seen these in HomeDepot for pond water diverting.
I was toying with the idea of using an aftermarket truck transmission cooler for the radiator (around $80). Should be plenty of cooling surface area. This would be mounted in a cool (not freezing) crawl space on the other side of the wall from the media closet. My media room walls are made of 9 inch think foam form concrete filled walls, so no issue of noise from that crawl space. The pump (two for redundancy?) would be mounted in a sealed tank (custom made out of PVC pipe with threaded ends to pull the pump out with expoxied wire connections?) There would be need for a drain to service the system and a way to fill and bleed the system of air at the top of the water column.
I haven't done any searching yet for pumps up to the task. If submerged need waterproof. Need to handle the volume of water and weight of the water column as well as the water drag from probably 20 feet of total tubing (supply and discharge). Need reliability. Need for probably 1/2" fittings. If not submerged, need somewhat quiet (a hum or less?) as this will probably not be in the media room closet.
Any thoughts from the forum on the pump? Are PC clocker pumps up to the task? I've been looking at the Eheim 1060 which is rated 600gph and 10 foot water column (needed for the overall height of the equipment rack).
Would need a way to quick disconnect each device for servicing without loosing the water. I think the PC clockers have such water cooling connectors - but they are pretty expensive at $25 per connection or $50 per PC.
Standard PC water blocks for CPU, chipset and graphics card on the HTPC and server.
Very slow large fan on the HTPC and server to vent the remaining heat from RAM / Hdrives out of the chassis. Would love if there were a small radiator that could be mounted inside the chassis to absorb the rest of heat...
The goal would be to get rid of all the fans and heat generated by as many devices as I can in the media closet. That way the power amps are cooler until I figure out a way to water cool them as well
Comments?
Comments?
