hey BSR........
Did you ever get anywhere with the water detector project ?
Quoting......from the HomeSeer board....
"Yes correct. With the same reasoning as my post with the 2000 ohm resistor above, the water resistance must be higher than that and thus not work.
I was actually looking at THIS cheap water alarm kit.
You could probably operate a cheap relay in lieu of the buzzer and have the DS10A monitor the contacts of that relay.
They also make THIS low water alarm that detects the absence of water (for your dog's water dish).
EDIT I ordered those kits, will update results after testing them."
