CAI, or anyone who's used the counters on the WC32, can you give me some more specifics on them please?
While I can find references in the manual to "COUNTER1", "COUNTER2" and "COUNTER3", there's also a reference to "COUNTER" (no number) which states it will count to a maximum of 2MHz.
Does this also apply to COUNTER1-3? If not, what speed can it count to?
WC8 also has frequency - that entry has been commented out of the WC32 reference, does that mean no time component in this one?
I see in the setup page for the counters that I can set them to count on rising, falling or both edges. (Does the 2MHz limit apply to the input frequency, or the counting rate? Ie, a 2MHz signal counting on both edges would have a 4MHz counting rate).
Which TTL input connects to which counter? (one could assume TTL1 -> Counter1, but that's a dangerous assumption)
I don't see a command to clear the counter - do I assume it's done with SET COUNTER1 0 ??
Are they full 32-bit counters? Are calculations done on them unsigned or do they flip to negative at 2^31?
Thanks!
Thanks!
