I'm looking into retrofitting a small UPB system into my condo, and I like the look and featureset of the SA-style UPB dimmers. Was planning on standardizing on the Web Mountain SW-7 second generation switches.
However, I have four track systems which use MR-16 heads with electronic LV transformers integrated into them. They are the Halo-style H tracks. Currently they are run off cheapo 600W triac dimmers. There is a slight buzz in a narrow range of the dimming, but I have not had major problems.
Running these lights without dimmers is not an option. I know PCS makes a dimmer for electronic LV lights, but I would prefer to not spend an extra $150 per circuit if I don't have to. (Honestly, I'd rather spend that money replacing the fixtures, which are nothing special.)
So, my questions are:
Worst case, I suppose I can swap out the LV MR-16 heads for PAR16 line-voltage heads, eliminating the transformer entirely. But I'd rather skip (or at least forestall) the hassle and expense if I can.
Thanks -- d.
- If I'm already using triac dimmers without a problem, can I swap in the SW-7s without an issue? Or will line noise that I can't hear be a problem for even the Gen2 devices?
- If not, are there other LV track heads I can use that *would* work with the SW-7s?
- Is there any risk of damage to the switch if I use these lights, or just to my transformers and my sanity?
Thanks -- d.
