BraveSirRobbin
Moderator
I am running older versions of MainLobby (ver 2.86b) and WebLobby on a MainLobby client machine (i.e. not the MLServer (ver 1.3.5) machine). I also have a TouchTronix UTMA touchscreen (with latest firmware) running an "instance" of this client machine via UTMA software (which came with the unit).
The problem I'm having is that I CAN run MainLobby on both the MainLobby client machine AND the UTMA TouchTronix device with no problems except when closing a MainLobby scene with a WebLobby swf "Background FX" (component).
Since you have to use the "web.close" command specific to the name of the MainLobby client; when you close a scene on the UTMA screen it also closes the weblobby component on the client machine (since technically they are both "named" the same with regards to a MainLobby client name).
The exact syntax I'm using in the MLServe Cmd Exit Box is (MainLobby client name is "Mopar"):
I don't know of a work around that can fix this since both units use the exact same MainLobby scene, unless I'm missing something obvious (which does occasionally happen
). This is a big problem because the screen will close on the device (that is not being used) whenever someone clicks ANY scene that has a WebLobby component on it (since all those scenes use the web.close command). For instance I like to show the directory scene as a default as it has my front door web cam image on it. If someone was using say the UTMA display to navigate MainLobby scenes, the main client's directory scene will have its camera WebLobby image disappear whenever a scene (with a WebLobby component) is closed on the UTMA screen. I'm also thinking this would be a problem if someone had multiple UTMA devices as any device that issues a web.close command would close ALL of the clients.
I tried looking for an option/command to refresh/reload the scene/WebLobby FX component, but without success.
I'm hoping I'm not the first to encounter this problem and some wise member will have a fix for me!!! :lol:
I would be more than happy to upgrade my MainLobby/WebLobby software (I already have the licenses), but I'm not sure this will fix the problem as you (if memory serves me correctly) still have to use the web.close command to properly shut down a WebLobby component.
BSR
Code:
MLServeCmd.MLCmd|MLCommand~Mopar~Web.Close
BSR
