HighTest
Hello fellow enthusiasts and professionals,
I recently have upgraded my home with a structured media center (Home was built in late fall of 2000, my Wife and I purchased it two years ago). I did a full retrofit on the wiring after I through a fit. When intending to add another line to another room, I found that the entire house had been daisychained rather than home run.
I yanked it all out, ran conduit into the attic space and rerun two Cat 5e to each room in the house and ensure extra space for additional wiring in the future. Each room had RG6 already, so I didn't have to worry about that.
It all comes back to a custom job Leviton enclosure (I didn't like their 6 port Cat 5e cards, so I purchased several 12 port Cat 5e patch panels and mounted them inside the case for more capacity then their normal mounts would provide.)
Anyways, with my desire to take video and audio to other rooms, I've been bitten by the home automation bug. I'll start out small, but will eventually move up to touchpanel lcd's and the works.
I was originally looking at an HAI Omni II controller, but after reading this forum it seems that they are not as enthusiast friendly. I understand that the Elk is also interesting.
My question is if I go with a PC based solution that could also be serving as the homes central media server, what would you recommend in conjunction? I was hearing about the ADI Ocelot, but wanted to find out more information and how well that worked for some.
My thinking was a PC with a connection to an Ocelot, some USB connections to UPB and Medio Home Bot or another good software application (HomeSeer looked interesting but then I saw the poll about version 2.0 and more than 50% not able to use it bug free).
So forgive the fact that I'm a greenhorn and if you have suggestions, I'll gladly learn from your experience.
Thanks!
Thanks!
