felixrosbergen
Gents,
Getting ready to pull the trigger to get the server for the new house (under construction) which is to function as:
- Sage TV server (headless, using all HD extenders)
- CQC Server
- File Sharing
- Itunes
I have not decided yet, but am considering Windows Home Server for this.
For hardware energy efficency is a major concern, also performance ofcourse, but i don't think any of the above are real performance hogs. I may at some point run a HDMI and DVI from this server to the main TV to allow it to be used to surf the webb etc, but this is not a major requests/issue.
Cost is not a major concern, but since this machine doesn't have incredible performance requirements i don't see why i need to spend a great deal on money on it either.
For the above I am pondering the following issues:
- CPU, need something reasonbly powerfull but energy efficeint at the same time. I prefer Intel for various reasons. What Socket type/speed woudl be appropriate?
- Hard drives, seems a no-issue. The WD Caviar greenpower drives will likely be chosen
- Motherboard:
- Which type and how many PCI and PCI Express slots do i need? I will be looking for several Hauppage TV tuners cards, video card, possibly card with serial ports, possibly modem.
- # of SATA slots. Seems like many mobo's have 6 now, i'll probably consider this the minimum.
- Memory
- Quantity? Considering 2 GB to start with.
- Type?? Seems like the DDR3 is more energy efficeint
- Other 'green' feautes like throttling back everything when the power is not needed.
- Audio head? What do i need?
Current considerations, in order of preference:
- Gigabyte IP45 chipset based mobo's. They have 18 different versions...differing mainly in RAID support (yes/no), Memory TYPE (DDR vs DDR3) and LAN connections (Single, Dual Teaming or Quad Teaming). Noting that i dont' need multiple gigabite LAN connection, and DDR3 may provided better performance and ergergy efficiency it cuts the list down to two boards GA-EP45C-DS3 and DS3R. The difference is that the DS3R has raid functions. This may be handy for RAID 1 OS drives and key date. I don't plan to do any RAID for the video storage drives. Prices seem pretty close, so I'd probably go for the RAID version anyway...streets for about $150 It also has a bunch of dynamic engergy management functions which look interesting. I expect this server to do pretty much nothing for many hours of the day so it needs to dial itself down a lot.
- Abit IP45 boards...not sure which yet...
Any suggestions / comments?? Anybody have exprience with the Gigabute EP45C-DS3R ?
- CQC Server
- File Sharing
- Itunes
- Motherboard:
- Memory
