I was curious if there was any reason why the approach below would not work:
The window: Not sure of the terminology, but the window has two moving sections (top and bottom). The lock is in the center where the top and bottom overlap.
Question: If using a wireless sensor, can't I just put the magnet closest to the window and the larger piece on the top of the lower portion of the window?
This way if either part (top or bottom) is moved, the connection is broken and the alarm is triggered. It seems to fit fine, and makes sense, just wasn't sure if I was missing anything.
My other option is to put two recessed sensors in, but I was trying to avoid drilling the window and spending twice as much on the sensors. If there is a reason to go that route (other than the above method allows you to see the sensor) that is another story however.
Any opinions?
Any opinions?
