I have started installing my first OmniPro II (and first real security system). I have already connected the control panels (4), doors, windows, OH doors and thermostats. However, I got to the glass break and it's really messing with my head. I think I understand what I need to do, but want to throw it out there to make sure I understand it correctly.
On my DSC AC-100 sensors, I'm pretty sure I will connect the +Red and -Black to the Auxiliary ports on the HAI Controller. Then connect the Green and Yellow to the Zone + & - (along with the EOLR at the end). On the AC-100 Sensor itself, the Green would connect to the C (Common?) terminal and the Yellow would connect to the NO (Normally Open). Since I'm using the EOLR, this should be a NO setup and not a NC...right?
I have a motion sensor that has a similar wiring scheme. I'm assuming the same applies to this device, too?
6 x AC-100 @ 35mA = Total 210mA (each sensor on separate zone)
2 x Motions @ 25mA = Total 50mA (each sensor on separate zone)
(total cannot exceed 1A)
Do I understand this correctly?
