dummptyhummpty
Hey all,
I signed up here a while ago after seeing IVB's posts over on AVS Forum. I posted my questions there, but didn't receive as much feedback as I had hoped for.
I'm looking to wire my house with Cat6 as Wireless N isn't cutting it. My house is a two story with a slab foundation. I'm planning to terminate the cable on a side wall of my attached garage (finished walls too). The current cable TV and phone lines terminate in the same location, but have to be accessed from the outside. Each cable TV jack has it's own coax cable, while the phone lines are daisy changed. I plan to run the cables up the wall, across the garage ceiling and up into and through the wall of the room above. This will get me into the attic where I can drop down in to each room, following the existing phone wiring.
Will there be any problem with me locating my terminations in the garage? I plan to locate the cable modem, router and switch with the wiring. I originally had planned to locate some computers there as well, but I will end up putting these in a room in the house. If I stick with the garage location, I will most likely bring the cable TV wires into the garage and clean up the cabling a bit (big mess of splitters and boosters).
Should I get a structured media cabinet or just use a patch panel mounted to the wall. I guess a cabinet would look nicer. Also since the wiring will be running up the wall and across the ceiling, should I look into conduit? The conduit will still be exposed, but might look nicer than a bundle of cables.
I plan to run four network jacks to each room. I was wondering if I should run another cat6 for phones? Our house is wired for four lines and we haven't had any issues with the current daisy changed wiring.
Lastly, distributed video/home automation isn't part of the plan due to time and money. Is there anything I should still take into consideration while doing this? If I ever did want to do distributed media/home automation, the equipment wouldn't be located in the garage.
Here's a link to my AVS Forum thread.
Thanks!
Thanks!
