Here is my setup:
One zone set to Definition 23 Police Notification Audible. It is connected to a Visonic wireless panic button. EOL resistor setting. The Visonic is wired for normally closed with a 2200 ohm resistor. There is about 7 volts present at the panel when not pressing the panic. When I press the panic the zone goes to about 13 volts. When I walk test the zone and press the panic, the interior speaker yells "panic, panic, panic", as I have programmed.
Here is my problem:
When I press the panic button, not in walk test mode, either from an armed or a disarmed state, instead of going into audible police notification with interior speaker yelling at me, I get a police trouble on the zone. I then have to enter a user code to clear the beeping. TIA.
Here is my problem:
