Zone Temperature Sensors for M1G?
fleetz
Is there any other zone temperature sensor option that could be used for the M1G other than the standard ELK ELK-M1ZTS unit?
I am going to use 9 zone sensors on a new building we are about to build. These will be use to provide some basic integration for the Daiken multi split A/C systems going into the new house. Each of the 9 head units will be fitted with a relay interface board that will switch the heads on or off under the M1G control.
It would be nice to find a more elegant solution than the ELK-M1ZTS. Any suggestions?
Does anyone knows of a more integrated control solution over a multi split air conditioning system?
Fleetz
fleetz
You teaser you! (-:
My time line is next 4 months do you know if this will pop out before then?
Regards,
Fleetz
