upstatemike
Anybody know if there is a difference between PLCBUS and X-10 version 2? Are they just two names for the same thing? (The specs look the same.)
Look at www.plcbus.com Both systems are not compatible but should peacefully coexist (AFAIK).
X10 version 2 is a good improvement of the old fashined X10 and fully compatible with the usual X10.
You can adress 256 different devices via a 120 kHz carrier. Switching with a second delay. And in most cases ok.
The PLCBUS-System can adress 64000 devices, is operating with another carrier, another modulation, is faster, more resistant to line-noise and some options more. All together much better, - and more expensive.
For me, there is the question if the PLCBus is the same or compatible with UPB ? I beleave yes, is it ?
I have X10-2 and PLCBUS home, and I think I can answer your questions.
1) X10-2 is just X10 with an other marketing name, and modules have features not commonly available on standard X10 modules. Modules support Scenes (they can react to up to 16 addresses), they have a good sensitivity, and some modules have an included X10 filter. Nothing more than X10.
2) PLCBUS is not based on X10. This is a completely new technology, however PLCBUS commands and PLCBUS addresses are very similar to X10.
PlcBus is not compatible with UPB (as it's 220V 50Hz).
PlcBus peacefully coexist with X10.
Pros:
- not sensitive to line noise (never had any problem here).
- faster than X10.
- Plcbus fast polling can report the status of 16 modules in less than one second.
- All modules support up to 16 PlcBus scenes with individual dim level and ramp rate.
- All modules support status requests
- All modules support command acknowledgment.
- DIM is better done than X10. There is a DIM-START or BRIGHT-START command, then a FADE-STOP command is sent when the button is released. This does not use all the bandwidth as long as the DIM button is pressed like X10.
Cons:
- modules do not report when operated locally (must use fast-polling). It's a shame ! PLCBUS with local operation report would be the perfect HA protocol for me !!!
- Shade/blind module only supports 45W (must use additional relays for most applications)
I'm going to try to fill the holes in your comparison charts. If a question is not answered, this is because I don't know.
Dimmer switches: YES
Can set default level for local operation of dimmer: YES
Can set default ramp rate for local operation of dimmer: YES (via software)
True relay on/off switches: YES
Any switch can link to any other switch: NO
Switches report status when operated locally: NO
Keypad with status led for each button: NO
Devices are immune to false activation from noise : don't know
Devices are immune to failed activation from noise : don't know
Switch and keypad firmware is field upgradable: NO
Retrofit "no neutral" devices: YES (some modules)
Shallow form factor: YES
Dual load switches: YES
RF "stick a switch": YES (same as X10)
Screw in relay module: NO
2-pin lamp module with local-control: NO
3-pin lamp module with local-control: YES
Appliance modules with local control: YES
True rocker or toggle: YES
Rocker/toggle color change kit: YES (for crystal switches)
Dimmers have led level bar: YES (for crystal switches)
Double-tap for fast on: NO
Wired tabletop controllers: YES
RF remotes: YES (same as X10+encrypted)
RF Keyfobs: YES (same as X10+encrypted)
RF motion sensors: YES
Wired motion sensor: NO
Companion switch available: NO
Any switch can trigger a scene: NO (need special switch)
Solid state ON/OFF switches: YES
IR Bridge: YES
Permanent device addressing: NO
Assignable device addressing: YES
Reports load changes: NO
Continuous status polling: Possible (PlcBus fast-polling)
Remote Link/Scene programming: YES
Remote device enrollment: NO
Remote programming of local settings: YES
Remote factory reset: NO
Remote device diagnostic: YES
Shade/blind control: YES
Conditional programming: YES (using software)
Sequence programming: ?
Cons:
I have to ask a stupid question. What is the result to my HA system if PLCBUS will not report in operated locally? If I turn on a light via the switch plate my HA network will not know it's state? So then my LCD control screen cannot tell if it is on or off? Or for that matter, my iPhone? Please clarify as I am about to build and want to use these devices since I live in China.
