C
chucklyons
Guest
So I thought I'd share this nugget of knowledge with the few folks here - (my wife isnt quite sure why I find this amusing)
I have a script that ensures that street light is sync'd with the sunset/sunrise cycle via a RadioRa switch. I've been converting to the Ras; solid rock hard and stable, but expensive.
So I had two new ones to replace traditional switches in a 3-gang box. Pulled out the two old ones, left the existing RadioRa in the 3-gang. Flipped the power off to the section of the house that has that particular box, and also the rack containing my Premise Server. Installed the two new Ras, flipped the power back on, try the paddles, success! Turn the power back off, button everything up, flip the power back on, try the paddles, and the street light would go on....and then immediately shut off.
Well, the obvious answer, although not to me at the time, is when iI was bouncing the power to that circuit, Premise was powered down. When I finally buttoned everything back up, filled with the pride of a job well done, Premise was powered back on.
And of course, the script was working as designed...making sure that light is off during the day....
Sorry, had to share :wacko:
