This evening, I noticed that the low battery indicator light on my standby genset was on. I don't know why yet, but that's not the reason for this thread. As far as I know, the low battery light could have come on as long ago as August 25 (last time the genset exercised), or it may have just come on. That got me to thinking about maybe somehow I can monitor the battery level and trigger an alarm if it goes too low.
The genset manual says the light will come on when the voltage drops below 12.2 VDC for more than a minute, or it drops below 8 VDC while the genset is running or below 6 VDC when the genset is cranking. So it would be really cool if I could mirror those events and trigger various actions based on whichever one occurs. I have a relay that tells me when the genset is running. I was thinking of tapping off the genset starter solenoid so I could tell when the genset is trying to crank. So what I need is a way to monitor the battery's voltage. It would also be good if I could log battery voltage samples so it could be graphed if needed.
I am in the beginning stages of HA. I have CQC but not installed. I will be buying an ELK M1G very soon. There will be a remote can with a zone input expander and an output expander very near the genset.
The genset battery is a typical 12 VDC auto battery (group 26). It is on a trickle charger.
Ira
Ira
