I know what I am about to ask is off topic, but I also know that many of you are quite expert.
Perhaps what I want to do may even be illegal, but I assure you I have no malicious or illegal intent. I only want this for backup.
We have industrial machines that are computer based, and instead of a hard drive, use a compact flash card which contains the machine info and is bootable in windows NT. The cards seem to go bad more often than you might think, and then we are out of production for at least two days till we get another CF.
The OEM has provided us with a CD that is written in LINUX, and is supposed to make copies of the CF using the PCMCIA slot to use for backup. It is not particularly reliable for reasons unknown to me, and if we get backup CF's from the OEM, they almost never work without them having to Email me with additional files, which I must install, or sending them back for some sort of fix. Meanwhile the machine is a giant paperweight.
I could go on with more explanation, but my question is pretty simple. Seems to me it should be possible to make bit for bit copies of the CF that would work identically in every way to the original. Perhaps my question is simplistic , but can you light up the address of each memory location of the CF, and copy what appears on the data bus to the same address on the second CF? Is that possible, and if so, does anyone know specific hardware and software to do it on a very small scale ( 6 CF's , but thousands of dollars in lost production).
thanks in advance
thanks in advance
