lupinglade
I've installed a Two Way Voice Module and at first it was working perfectly, but recently I have found that there is a lot of noise coming from it whenever it plays any audio or if the phone intercom is used. Its similar to a cell phone interference buzzing sound that goes on and off and is very annoying. There is no cell phone near the HAI controller/voice module. I've tested with headphones plugged into the jack and the noise is still there. I've tried moving wires around and removing the voice module board and moving it a bit further from the other wires and the voice was still there. I've also tried power cycling the controller to no avail. Its a Rev C board with the trigger+headphone jack. No mic or speakers connected, just wired up to a NuVo Essentia (or headphones in this case).
Any ideas? Is it a bad board? I'm confused because it seemed to work without interference before, but nothing has really changed around it and I've tried powering off all near by electronics and it makes no difference.
The sound buzzes slowly first (low hz), then buzzes quickly then slowly then stops for a bit then repeats.
