Can i replace my 7.5 volt wall wart with a 12 volt power supply?
#1
Posted 22 July 2012 - 02:43 PM
I'd like to hardwire my network gear to the altronix, to prevent a momentary outage while the ups cuts over. I've already plugged in my 12 v wifi routers and telco equipment. However i have two switches, one at 7.5 volts (1 amp) and one at 5volt (1 amp). Both are from trendnet. Any ideas if i can just connect them? The manuals don't give a dc input volt input... How do i know if the switches can handle the higher voltage? (many consumer devices allow a wide range of input voltage)
#2
Posted 22 July 2012 - 03:04 PM
Just make sure the converter/regulator can handle the current.
Edited by BraveSirRobbin, 22 July 2012 - 03:05 PM.
#3
Posted 22 July 2012 - 06:16 PM
For 7.5 you'd have to make a variable using a LM317 and other parts. I'd put a multimeter in the adapter and make sure it's actually the voltage it claims first. Or just buy a pre-made one like these.
#4
Posted 22 July 2012 - 06:41 PM
#5
Posted 22 July 2012 - 07:17 PM
#6
Posted 22 July 2012 - 07:42 PM
Electronics don't work well after you let out the magic smoke...don't try to feed more voltage than the wall wart or device's power supply is rated for.
#7
Posted 22 July 2012 - 10:22 PM
If you are reading this off of the wall wart, you may be misled. The ratings (current in particular) printed on the wall wart are the capabilities of the wall wart - not the load requirements which are likely much less. If you can't find this in the specs for the load, it is very easy to measure with a DVM.
#8
Posted 22 July 2012 - 11:29 PM
I used an LM317 in my car monitor schematic because I wanted to have a voltage slightly less then nine volts. You can see how it is implemented with the schematic below.
What standon was most likely mentioning was to measure the regulated output voltage (under load) in case you need to make slight adjustments in the ratio of the two resistors (in the case of the schematic below it is the ratio of the 270 ohm and 1.6Kohm resistors).
You need to incorporate an 'adjustable' regulator if a 'standard' regulated voltage is not used. This is why another regulator was mentioned for the five volts as it is 'fixed' for that voltage.
You will need two separate regulators feeding off of the 12 volt for each voltage. You can just get two adjustable regulators as well and just set one to five volts also if desired.
Considering you are at the edge of the LM317's current output, I would recommend the LM150, most likely use the TO220 case for ease of installation. You should also get a heat sink for it. Jameco is a good source for these parts.
Don't forget to fuse each input (before the regulator) also.
One nice thing about a regulator is the front end voltage (in this case the 12 volt source) can vary, but the output will remain constant (unlike the cheaper wall warts).
There are a ton of sites that can suggest other regulation circuits/methodology as well.
Of course, as I mentioned above, there are other alternatives.
#9
Posted 23 July 2012 - 12:05 PM
I would look seriously at switching regulators. They are a bit more complicated but will be much more efficient. The battery backup will last longer this way too. National Semiconductor has a "simple switcher" series that have detailed ap notes so very little real design work is needed. Other suppliers have similar stuff.
#10
Posted 28 July 2012 - 04:24 PM
Let me ask a slightly different question. Don't most electronics have a range of DC voltage that's acceptable? All I know is the DC adapter that shipped with the unit, but I'd bet the switches themselves can handle a range of DC voltage. If I tear open the case, what does one look for to determine what voltage is acceptable?
On more expensive electronics, the manual might indicate "9-12v DC", but on these things, there's nothing printed....
#11
Posted 28 July 2012 - 05:04 PM
The manual showing specifications on the product should provide enough data on the current draw.
#12
Posted 28 July 2012 - 07:27 PM
I assume I'd have to be in series with the power, but my electronics knowledge is a bit rusty.
Yes, it's just that easy! Connect in series and set to measure current. Use the lowest range possible to get the best resolution.
Keep in mind that this will give you an average current measurement. Be sure to add a bit and have plenty of capacitance when you design your regulator.
Edited by jpmargis, 28 July 2012 - 07:31 PM.
