CAI_Support
WC32 has two serial ports. Current firmware uses both serial port to communicate with remote computers. The WC32 only configure the RS232 ports speed, it does not do any local processing of the RS232 data. In the future firmware, we do plan to take one RS232 port for local control.
Currently, user wants to use the RS232 port, will need to install a Null-modem emulator software (com0com) on your PC. This emulator software is an open source software from SourceForge.net . Since we can not post URL in this forum, please do a Yahoo search on the Yahoo site for it.
Then you will need to contact us to install a software called WCBRIDGE.exe, a command line software, to bridge the com0com to your local COM1 to COM4. Then your terminal software will be able to communicate on the devices connected on the WC32 RS232 port, over local or remote network.
Suppose com0com installed and connected to WC32 as CNCA0 and CNCB0, for both RS232 ports, running this command below will setup the first available com port on your PC:
C:\temp\wcbridge.exe uart CNCB0 192.168.1.15 &
TcpSocket connection to 192.168.1.15:4500
where the 192.168.1.15 is your IP address on WC32 board. 4500 is the port RS232 configuration set on WC32.
