newalarm said:
On other keypads, if you don't hit the right code, the beeping continues (i am pretty sure). Why would they make it different on this keypad?
I tested my M1KP. When you are exiting the beeping during the countdown stops if you hit a key during the countdown .
When entering and the alarm is armed, there is a constant tone during the countdown (15 sec) and hitting keys momentarily interrupts the constant tone for the duration of the keypress.
I tried the same on my Detached Garage (Area2) with the KP2 that is there. It worked the same as the KP in the house.
So to clarify, on exit, key presses interrupt the 1 second interval beep. The beeping stops.
On entry, key presses interrupt the constant tone for a very short time during the keypress but the constant tone continues until a code is entered that is correct.
My guesses:
1. There is bug and the NAV is intended to operate like a normal KP.
or
2. It is completely different than any other keypad that Elk sells, intentionally.
I also did notice that the NAV does not have the constant tone on entry countdown like the other keypads do. It beeps on countdown, once per second until 10 seconds then twice per second.
(When all keypad(s) countdown(s) get to 10 seconds the beep turns to a double beep, once per second)
Not sure what to make of it. I have never heard this brought up here before.
To go back to your original post, tell people "Don't walk away until it is green". A simple solution for now.
