Has anyone tried to install the remote temp sensor without using a shielded cable? I have a short run (~10 ft) between the stat and the sensor, and was planning on tieing into an unused pair from the cat5 I ran between the stat and the OPII, but it is just standard unshielded cat5. Would make the install quite a bit easier if I didn't have to run a new wire...
