New stuff for WC8/32
BTCAD
Hi guys,
              I just want to show you devices that work well with wc board.
Maybe it would help someone.
http://www.ebay.com/itm/370899087938?_trksid=p2059210.m2749.l2649&ssPageName=STRK:MEBIDX:IT¸
(pin to screw converter) wc8
http://www.ebay.com/itm/370899097165?_trksid=p2059210.m2749.l2648&ssPageName=STRK:MEBIDX:IT
(pin to screw converter) wc32
http://www.ebay.com/itm/170911043548?_trksid=p2059210.m2749.l2648&ssPageName=STRK:MEBIDX:IT
(ribbon) wc8 ||||| For the wc32 i used an 40 pin hdd ribbon
http://www.ebay.com/itm/Ubiquiti-AirGateway-802-11n-150Mbps-2-4Ghz-WiFi-Indoor-Router-for-UBNT-PoE-/171279059551?pt=COMP_EN_Routers&hash=item27e1070a5f
(Wifi radio that can be setup as a station, acces point, router, bridge, router soho. 28db radio!) airgateway Long range also avaible.) I used since a lot of time ubiquiti's radio and it's the best cheap device on earth!
http://www.ebay.com/itm/331195998026?_trksid=p2059210.m2749.l2649&ssPageName=STRK:MEBIDX:IT
(dc voltage sensor) It works very well on wc8. Analog out and also a Digital out (pot for adjustment) !!!!!!!!!!!!
                       DIV AIP1 20 VAR1 (var1 == real dc voltage)
or
                       MUL AIP1 104 VAR2
                       DIV VAR2 20 VAR1 (var1 == real dc voltage without (,) but more accurate )
