I'm using an elk SWB14 can for an Aiphone (LEF-5's and LE-D's) installation. Rather than daisy-chain all the stations, I'm a believer in home-running everything. So that brings 3 wires per LE-D and 15 wires per LEF-5 back to the elk swb14. The wires for the LEF-5's are 22ga, and the wires for the LE-D's are 18ga. Long story short, I need to join approximately 6 sets of 15 wires in the can.
My first thought was just put a 66 block in the can. However, given an aiphone power supply in the bottom (on the left, and a UPB supply on the right) a full 66 block won't fit. So then I thought about using two or three smaller 6pair by six 66's, but there doesn't seem to be a clean way to mount them to the swb14.
So two questions:
1) I found these: http://www.suttlesolutions.com/catalog/suttle-brands/soho-access/soho-modules/3-pair-66-block-connecting-module.html and two or three of those would be a very nice clean solution. But, anyone used them and know if they would mount right in the swb14? And if they'd mount right to the holes in the swb14, how bad is it to use 18ga for some of the wires on a 66?
or
2) Any better suggesting for connecting all the wires?
Would appreciate any thoughts/advice.
So two questions:
or
