Efried
In order to ease the coding I would appreciate a watchdog allowing to enumerate the events triggering a restart of the WC, like failures of 1- wire Sensors.
For my systems of WCs this does not help, because I should eventually reset the communication stack of a remote WC, or disable WEBGETS to this specific WC. Again some structured approach would be great, allowing at least variable names and If Then Else or better CASE Constructs, may be with the WC32. My WC8 will be replaced by cheaper and smaller passive modules ASAP, since distributed programming having code on several WC is too cumbersome. But may be I'm back if those WC8 will get a watchdog too, and variable names which might be extracted via JSON at the best....
thanks
thanks
