I just installed some insteon leak detectors in my home and was thinking about installing a water shut off valve to stop flooding during a leak. However, it occurred to me that it may be easier (and cheaper) to just control the power to the well pump if a leak is detected. Would this be a good solution instead of a more expensive water shut-off valve?
The power to the pump is 220v, and there is already a manual switch to turn power off/on. So, I was thinking of the insteon 2477SA1 normally open relay. My assumption was that if power is lost (and i have a leak) power to the pump would stay off when power is restored - the ISY would keep it off until I reset using my ISY programming. Is this correct?
Would constant power on the relay to keep it closed (and the well pump powered) cause the relay to burn out after some time?
If it isn't a good idea to control power to the well pump in the case of a leak, my other option was to install GreenField Direct ASV075 3/4" Controlled Water Valve.
Thanks for any thoughts on this!
joe
joe
