So this morning, I tried to get into my OPII using PCAccess3 to turn off some automation I don't need anymore. Connection failed so I went to the panel and noticed I no longer have a link between the OPII and my switch. I haven't connected to it in awhile so I have no idea when it stopped working. I go through the following exercises to try to pin down the problem:
- Tried 3 different cables
- Tried known working ports on my switch
- Tried connecting to another switch I had laying around
- Tired forcing the speed and duplex on the switch port to 10Mbps/full
- Unplugged the power and battery from the OPII for about 10 minutes
- Reset the OPII RAM
- Reset the OPII EEPROM
Nothing in the configuration seems to have changed (e.g. IP addr, MAC addr, etc.). Even if they had I wouldn't expect to not get a link. I can't find any configuration settings that would enable/disable the Ethernet port.
Am I missing something or has the Ethernet port died on my OPII? If it's the latter, I'll be pissed. The warranty ran out about 10 months ago. I'm hoping it's just an oversight on my part and one of you Cocooners can point out some config setting I'm just not remembering.
thx
cmarcus
thx
cmarcus
