smithfrank
On the WC8 it was possible to save UROM values from other than the WC web interface. Both the WC8 and WC32 PLC guide contain this tex:
from 3.02.17 firmware, WebControl supports manually set a UROM value from outside, uromid from 1 to 4:
http://192.168.1.15/api/seturom.cgi?uromid=1&value=23456789
Command line browser wget can be used to do manually control. The above lines maybe need in double quotes to work.
I have not had success with the WC32 to do this. Can someone provide guidance? Thanks
