Just installed a new omnistat 2 (replaces a Honeywell thermostat); all connections are correct; setup is correct - multistage conventional (Trane 20xi)
When the thermostat is on cold - the AC blows heat
When the thermostat is on hot - the AC system blows heat
The original thermostat worked without any problems (changed to omnistat2 for humity settings)
Thank you for your help
