T tparvais Member Feb 4, 2017 #1 Hello Is it possible to read via URL GET value of VAR1 ? I've a piece of code that make some tests and set VAR1 according AIP1 value I cannot find this WB8 - FW V 3.00.7 thank you
R rossw Active Member Feb 4, 2017 #2 Thomas Parvais said: Is it possible to read via URL GET value of VAR1 ? I've a piece of code that make some tests and set VAR1 according AIP1 value WB8 - FW V 3.00.7 Click to expand... That's ancient firmware. Your options back that far were a little more limited as I recall. Try these. I think this one worked on early versions and just spits back the integer value http://admin[email protected]/getvar1.cgi I can't remember when these were introduced, and they'll require parsing: http://admin[email protected]/getall.cgi http://admin[email protected]/api/status.xml
