Noticed it personally (on Ubuntu 16.10) helping another user in the last week or so. Easy to fix but a PITA to deal with. I was amazed deleting the created cron job watching it recreate itself within seconds. Over the last week or so noticed one new application eating some 35% utilization and total upload (nic out) cumulation totals going to the Gb range bringing the new Intel iSeries (with 16Gb of RAM) down to a crawl not doing anything?
Following is a synopsis from Googling.
At the end of September 2014, a new threat for the Linux operating system dubbed XOR.DDoS forming a botnet for distributed denial-of-service attacks was reported by the MalwareMustDie! group. The post mentioned the initial intrusion of SSH connection, static properties of related Linux executable and encryption methods used. Later, we realized that the installation process is customized to a victim’s Linux environment for the sake of running an additional rootkit component. In this blog post, we will describe the installation steps, the rootkit itself, and the communication protocol for getting attack commands.
Installation Script & Infection Vector
The infection starts by an attempt to brute force SSH login credentials of the root user. If successful, attackers gain access to the compromised machine, then install the Trojan usually via a shell script. The script contains procedures like main, check, compiler, uncompress, setup, generate, upload, checkbuild, etc. and variables like __host_32__, __host_64__, __kernel__, __remote__, etc. The main procedure decrypts and selects the C&C server based on the architecture of the system.
In the requests below, iid parameter is the MD5 hash of the name of the kernel version. The script first lists all the modules running on the current system by the command lsmod. Then it takes the last one and extracts its name and the parameter vermagic. In one of our cases, the testing environment runs under “3.8.0-19-generic\ SMP\ mod_unload\ modversions\ 686\ “, which has the MD5 hash equal to CE74BF62ACFE944B2167248DD0674977.
The infection
During the rush of #shellshock we saw another new threat emerged. We saw an attack log of one-liner shell script being injected via ssh connection. By the attack source+CNC IP and the payload, this looks like a China crook's new hack scheme to spread new ELF DDoS'er threat. This is spotted silently spread during the #shellshock waves, noted: it was NOT using #shellshock exploit itself.
The infection
