Features
Subscription to ISY for realtime updates
SSL Connections Included
Customizable button and status labels for most devices
Weather (iOS coming soon)
Requires ISY Weather Module
Access ISY from home network
Access ISY from outside home network
For example, using Cellular data, or at your work. May require port forwarding on your router, and possibly special service through your Internet service provider
Access ISY via UDI Portal
Prioritize connections
Multiple ISY connections
Connect to the same ISY more than once, e.x., for "user profiles," or connect to more than one ISY
Securely encrypted and SALTed ISY login data
Optional PIN access to launch profile
If enabled, login data stored on device is encrypted and SALTed with your PIN
App shortcuts
Android only, requires Android 7.1+. iOS coming soon
Run in background service
Android only--iOS doesn't seem to support this, but we're trying to find a way.
Add INSTEON and X10 devices to the ISY via Agave (Android only right now)
Add Scenes to the ISY via Agave (Android only right now)
Add and edit Rooms (ISY Folders) to the ISY via Agave (Android only right now)
Family Access Manager
Add Agave access to your ISY for your friends/family with customizable access level and remote revoke capabilities. Also useful to share your Agave purchase on Android with your iOS devices or vice-versa! Add Family Manager
Devices
ISY Scenes
On/Off Switch Relay
Dimmer Switch
IO Linc Sensor/Relay
Triggerlinc Open/Close sensor
Motion sensors
Smoke sensor
LED light bulbs (INSTEON, Z-Wave)
Door locks (Z-Wave, INSTEON Lock Controller)
Sprinklers (EZFlora/EZRain)
Variables and Programs
Run programs in all conditions; customizable variables; custom naming for app-readable variables, standard input, toggle (ON/OFF); customizable status and buttons options; slider; customizable min and max values Variable/Program Add-On
Thermostats
Control and navigate thermostat controls Thermostat Add-On
ELK M1 Security (may be minor differences between iOS and Android right now)
Control and manage your ELK M1 control through your ISY: Arm/disarm areas and view zone statues, control all output functionality, custom naming for better app viewing, ON/OFF controls, optional auto-off timer, momentary control
