OmniLinkBridge is a C# service that allows you to control your OmniPro II controller from SmartThings (Web API) and Home Assistant (MQTT). You can also use it with NodeRed (MQTT) to create flows for advanced control of your devices. As the successor to HAILogger is also provides logging and notifications. You can download and/or contribute on GitHub.
The big feature for this rewrite is the MQTT module. To get started with Home Assistant you need an MQTT broker such as Mosquitto running and a Windows (.NET Framework 4.5.2) or Linux system (mono) to run OmniLinkBridge. Once configured Home Assistant will auto discover and add the OmniPro II devices.
configuration.yaml
OmniLinkBridge.ini
Out of the box with Home Assistant 0.80.0 there are two caveats. For full functionality you will need to add a custom_components folder to your config directory and override the following. Links to the pull requests are below, so you can track the status of these being included into the next version of Home Assistant.
alarm_control_panel/mqtt.py Adds night mode
climate/mqtt.py Adds temperature low and high setpoints
configuration.yaml
Code:
mqtt:
broker: localhost
username: mosquitto
password: yourpassword
discovery: true
discovery_prefix: homeassistant
Code:
mqtt_enabled = yes
mqtt_server = hassio
mqtt_port = 1883
mqtt_username = mosquitto
mqtt_password = yourpassword
mqtt_discovery_prefix = homeassistant
