Setting up a new house and chose a coat closet to become my network closet. Right now it only gets up to about 80, but it is less than half populated.
I thought it would be easy to find a through wall ventilation fan. I can exhaust to the side of the closet into a utility space.
I thought I could just buy something, cut a whole in each side, and shove it in.
I am struggling to find such a thing, well, with a couple of caveats.
https://www.amazon.com/Broan-512-Utility-6-Inch-Plastic/dp/B001501LHK/ref=sr_1_1?keywords=B001501LHK&qid=1553008706&s=gateway&sr=8-1
(Broan 512 Room to Room Utility fan in case the link doesn't work).
something like this looks just fine, but it says 3.5 Sones which is about 45 dba I think, which is really loud. I do not want to hear it if I'm more than 5' or so away.
Infinity makes a bunch of "room and closet" fans, e.g.
https://www.amazon.com/AC-Infinity-High-Airflow-Equipment-Enclosures/dp/B0788ZMZ7X/ref=sr_1_1?keywords=B0788ZMZ7X&qid=1553008889&s=gateway&sr=8-1
But they are thin. Looks like I would need to frame up around it, essentially making a duct. They show it mounted in a door (at 2.28" it's a bit thick for a door though or I might consider it). Unless I'm misunderstanding -- it really otherwise looks good.
These look like a nice cheap way -- could just control with a smart plug -- but same issue, I would need to build my own duct.
https://www.amazon.com/AC-Infinity-Cooling-Ventilation-Projects/dp/B009OWVUJ0/ref=sr_1_1?keywords=B009OWVUJ0&qid=1553009031&s=gateway&sr=8-1
It's not that I cannot build my own duct, I can probably manage it, but I have enough DIY tasks right now that it is not high on my interest list.
I would really like to find something already made to just sit in a standard 4" wall, ready to go.
Anyone know of such a thing, or should I break out the sheetrock and mud or sheet metal?
Linwood
Linwood
