Jump to content
Here
  • Please log in to reply
4 replies to this topic
#1 rumb
rumb
    Cocooner
  • Registered
  • PipPip
  • 26 posts
Posted 04 January 2020 - 03:58 PM
I have a 12 year old Omnipro II system. Full security and lighting automation with Lightoleir Compose PLC switches. Several motion detectors that assist in turning lights and such on. Just upgraded board and added a Omnitouch7 screen. I have been working on adding IP cameras and have also added a Bitwise Controller and building touch screens. Just finished creating Theater components controls.  I will be using android 10" tablets. Also added Hai/Leviton wireless receiver. Are there any door transmitters other than the HAI ones that work with it?
#2 rumb
rumb
    Cocooner
  • Registered
  • PipPip
  • 26 posts
Posted 05 January 2020 - 11:33 AM
I bought some Sonoff DW1 433mhz door sensors and they dont work at all.
Is there any brand you know that does connect to the Hai Wireless receiver?
#3 mikefamig
mikefamig
    Cocoonut
  • Registered
  • PipPipPipPip
  • 3571 posts
  • Experience:novice
  • Hardware:Elk M1
  • Tech:UPB
  • CCTV:ip
Posted 05 January 2020 - 11:55 AM
No I'm not familiar with Leviton wireless system but pretty much all wireless systems use proprietary communications and you need to buy sensors that match the transceiver. I was referring to hard wired sensors.
Mike.
#4 RAL
    Cocoonut
  • Registered
  • PipPipPipPip
  • 2112 posts
  • Experience:average
  • Hardware:Elk M1
  • Tech:X10-PLC
  • Phone:POTS
Posted 06 January 2020 - 10:02 PM
If you have the 433 MHz 45A00-1 receiver, then I believe that will only work with HAI/Leviton transmitters, as Mike said.
Leviton does have another receiver, the 42A00-2, which is compatible with GE/Interlogix 319.5 MHz transmitters, as well as those from other manufacturers that make GE compatible sensors.
#5 SCAInc
SCAInc
    Newbie
  • Registered
  • Pip
  • 5 posts
Posted 12 February 2020 - 04:18 PM
I'm using the Alula NanoMax sensors with the GE/Interlogix 319.5 MHz receiver (42A00), mentioned above.  Picked the NanoMax because it is very small and unobtrusive.  Currently using on both doors & windows.
