... looking for the simple ability for scheduled control of SAI links and/or devices (e.g. - activate link 23 at 11pm, etc.). Could the existing drivers allow this? ... know that an ELK driver is in the works but looking for a interim solution. ...
Disclaimer: I have no experience with UPB.
Short answer: Yes, it should work.
In Premise, you create a
Schedule to control virtual objects (i.e.
Home-level objects). For example, you add a generic Light to the Family Room, create a Schedule that turns that light on at sunset and off at 11:00 PM and you're done.
OK, nothing tangible has happened yet because you need to
bind that light to a physical device and that's where the UPB
Device Driver (or X10 or Insteon) comes into play. You bind (drag 'n drop) the virtual Family Room Light to a real UPB light revealed by the UPB driver. Whatever happens to the virtual object will now happen to the real device.
Why bother with this two-layer division of virtual and real objects? I'm glad you asked!
Your virtual Family Room Light and Schedule are independent of the lighting technology. Unbind the light from a UPB device and re-bind it to an Insteon device and everything continues to work as per the original Schedule.
The main caveat is that the Device Driver
must support the desired physical device. As samgreco can attest, the existing UPB driver is dated and does not support many of the new UPB devices. Hopefully, someone with time and programming ability can revise, or recreate, a modern UPB driver for Premise (Gee, now I sound like sam!).
Or you can wait for me to complete my Elk M1 driver and control whatever lighting devices are supported by your M1 panel.
